monitors won't reset
hammertime
Year and Model: '04 XC90, '07 XC70
Has thanked: 1 time
Post by hammertime »
I have a '96 850 na that will not reset any monitors. I cleared a trouble code that I caused by unplugging the MAF while the engine was running. Since then the car has been driven for almost 2 weeks around town and 2 highway trips. Took it to my local garage and not a single monitor has reset. No check engine light and no logged trouble codes. Have been driving with an expired inspection for nearly 2 months now. Need to get resolved. Any one ever experience this.
'04 XC90
'07 XC70
Zamboni Model 545 (my work vehicle)
Prev. '68 142, '96 850 GLT Sportswagon, '98 V70 AWD, '98 S70 T5, '00 V70 XC
first car ever owned: '74 BMW 2002tii
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
They will not reset or they are not ready?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
hammertime
Has thanked: 1 time
I guess the proper term would be ready. The mechanic expected to see some of the monitors ready considering the amount of driving that had been done since I cleared the codes with my hand held scanner. My scanner simply shows readiness complete Y or N, the mechanic's scanner gave read outs of all the different monitors and not a single one was ready.
'04 XC90
'07 XC70
misha
Post by misha »
There is a specific "drive cycle" for these cars which needs to be performed to make monitors in ready state.
Search for "drive cycle" on the forum for instructions.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 1609 times
Been thanked: 4065 times
The EVAP ones don't set easily but if none of them are going ready I think you have a deeper problem than the drive cycle. Has the ECU been messed with at all?
hammertime
Has thanked: 1 time
Never touched the ECU. The battery got completely drained recently, wonder if that has anything to do with it.
'04 XC90
'07 XC70
misha
Post by misha »
Yes.
Drained battery left ecu without power and reset all it's data to factory settings.It takes a while to complete drive cycle and to gather parameters from every single sensor.
Like i said before....there is a special procedure to speed up ecu to complete drive cycle earlier.With everyday normal use it can last for a while,especially in stop & go traffic.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Keep driving it and report back in two weeks. It does seem long but let's see if you can break my Record of 2900 miles to reset all monitors to ready
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
Talk to the inspection station. Some 96-98 Volvos (and a list of many others) have exemptions granted and they only need to have no stored fault codes.
http://www3.epa.gov/otaq/regs/im/obd/re ... f08009.pdf
You can try to see if at least some will go to complete: http://new.volvocars.com/ownersdocs/200 ... ection.pdf
Hammer...if you are still in Crescent country I'm in BUF area on business a lot and can bring the scanner sometime
