T5 1997 brake component for front brakes
adrian22
Year and Model: s60 2006
Post by adrian22 »
I discovered that my driver front side brakes pads are badly worn out on this side only. The cause was because the last mechanic that changed the pads 2 years ago did not tied all the way the upper guiding pin that was loose and moved on in the hole to the point that grind up all the tread inside the caliper holder house.(that part I need)
Question is what is the name of the part that I need to order-located on the other side of the caliper, where the caliper guiding pins are screwing in?
It is not part of the caliper
Thanks
adrian22
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
Has thanked: 2199 times
Been thanked: 1852 times
If I read this correctly you mean the part that the guide pin threads into, or the caliper bracket
https://www.fcpeuro.com/products/volvo- ... car-141620
https://www.fcpeuro.com/products/volvo- ... 50-8251156
Hopefully this is what you are looking for.
