Has anyone had this issue?
The rotors and brake pads are new and volvo brand. I notice the issue mostly braking at low speeds < 10mph but occasionally at around 35mph.
Anyone know of a fix?
Thank you.
850R Right Rear Tire Brake Squeal at Low Speeds
- misha
- Has thanked: 152 times
- Been thanked: 402 times
Did you re-installed brake shims when you performed brake job?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Been thanked: 468 times
Brake shim is usually not the issue.
There are 2 issues that I have had to deal with over the years:
1. Brand: use the brand suggested by Ozark Lee (? Mintex).
2. Anti-squeal compound. I used this and it works for about a year, then it is squeaky at low speed braking.
So every year I have to re-apply the anti-squeal compound.
- Year and Model: Many Volvos
- Been thanked: 75 times
I use half shims and gobs of Sil Glyde brake grease on the back of the pads and both sides of the shims. That usually shuts them up.
