Cylinder head alignment studs
clifford06
- Year and Model: 2000 T5
- Has thanked: 6 times
- Been thanked: 4 times
Greetings. Happy Holidays. Do the two alignment studs on engine block ,that two of the head bolts go thru, serve any other purpose other than alignment of the head ? Thanks
clifford06
Thanks for reply. I noticed that my block was missing one. It was still in old head. Machine shop suggested removing them, due to resurfacing of head. Studs could cause overheat due to being removed for RR. He said the stud would be at factory specs , causing gap between head and block due to the surfacing of head. Thoughts and opinions respected.
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
The dowels are not as tall as the machined bore in those locations in head. You can cut the head and the dowels will not stop the head from closing down on gasket against block. The dowel is the same for any 850/s60/v70/s80/s40/v40/v50/c70/c30/xc90 block 4, 5, or 6 cylinder "white" engine.
clifford06
Do think I should get one from a PNP block.?
- 2153 Views
Last post by precopster
- 2066 Views
Last post by FLXC90
- 645 Views
Last post by three_jeeps
- 4386 Views
Last post by 850oldschool
- 442 Views
Last post by jholden19
