Hi all, and happy holidays!
I decided to tackle my PCV during some free holiday time I had, and I'd love some help figuring out what went wrong.
I'll admit up front that I started doing the work before I had disconnected the battery, only realizing it at some point when I was pulling off the fuel rail. At that point, I stopped and disconnected it, then continued.
After everything was back together, I started it up and got a wildly varying idle rate, from about 600-1,200rpm, back and forth, which you can see in the first video. When my brother arrived, he filmed the second video, in which you can see a spark (arc?) at one of the fuel injectors. After shutting the car off, a faint electrical buzzing sound could be heard in the vicinity of the PCV flame trap.
Is it possible/likely that I shorted part of the system? If that's the case, what's my next step?
Previously, I had a P0455 code, which I had hoped the PCV system replacement would address. Now, I get no codes, but the car doesn't run.
Any help would be greatly appreciated.
1998 V70 rough idle after PCV replacement
brunocerous
- Year and Model: 1998 V70
- Has thanked: 303 times
- Been thanked: 43 times
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
- humbertoflores63
- Year and Model: 1995, 97, 98
- Has thanked: 1 time
You need to unplug the battery first and recheck all the electrical connections from the items that you unplug to do the PCV service.
Make sure to fit the connectors properly, and also check the vacuum hoses for a proper fit.
brunocerous
It was running beautifully, although the PCV hoses were hardened and it failed the "glove" test.
brunocerous
That sounds like as good a place to start as any. I'm going to redo it now. Hope to have a positive update soon.
humbertoflores63 wrote:You need to unplug the battery first and recheck all the electrical connections from the items that you unplug to do the PCV service.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Go back and re-check every connector and vacuum line you needed to disconect.You messed something up during the process of replacement.
Usually,people don't install manifold gasket properly and car runs like crap.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Been thanked: 504 times
Been there done that.
Usually the hose to the ICV is disconnected, causing unmetered air to enter the system.
Check every single connection, clamps etc.
Also, the I.M. needs to be torqued properly.
- Has thanked: 311 times
- Been thanked: 817 times
By far the most common of rough idle after PCV is the little bracket is lodged under the bottom right corner of the intake manifold, leaving a vacuum leak.
Fear not, after you find the leak or hose, your chariot will run beautifully once more.
Ditto on the advice to inspect the manifold and IAC. If you can see sparks, track them down and stop that quickly before it damages something.
brunocerous
Thanks so much for the words of encouragement. It really does help to hear a voice of support.abscate wrote:Fear not, after you find the leak or hose, your chariot will run beautifully once more.
I see that the manifold bolts are supposed to be torqued to 18 ft/lbs., which I did.
Could the spark at the injector be caused by a vacuum leak?
I rechecked everything, every hose and bolt, and the car is stalling. When I cranked it, I could hear a clicking sound in the vicinity of the fuel rail, followed by a slight gasoline smell and a faint electrical-type buzz afterward. I don't have help right now to pinpoint the clicking sound.
- 1445 Views
Last post by RickHaleParker
- 13 Replies
- 2861 Views
Last post by Mr Wolf
- 2009 Views
Last post by jtp
- 2722 Views
Last post by DeadEric
- 17 Replies
- 1430 Views
Last post by vtl
