head job
ejbj
Year and Model: 164 S80T6 v70xc xc90
Post by ejbj »
Hi. I had a misfire and after a leak down test and sticking a tiny camera in the spark plug hole I was confident enough to take the head out. I found a burn exhaust valve.
I replaced it, but now the tappet/cam follower sits too high compared with all the other in the exhaust. how do i adjust this? i understand they are solid but cannot find size options to buy.
any clues?
thanks
Ed
123, 164, 245, 240, 740, 940, V70XC, S80T6, XC90T6 and a Toyota Prius to drive to the Volvo dealer or while waiting on parts for them....
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
What car and year are you working on?
If this is a 98 then my first thought is the valve stem is too long, where did you get the replacement valve? I would try swapping with another hydraulic lifter just to check that (but the lifters should always go back paired with the same valve they were with originally).
