headlights
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
dancone09
Year and Model: 2006 S40
headlights
Post by dancone09 »
i have a2006 S40 2.5 FWD. when I start up my car, my headlamps, taillamps, and dash lights are all on. My headlamp switch is in the off position. I don't have auto headlights,does someone have a diagnosis for this problem?
Tsquared
Year and Model: 11 C30
Has thanked: 1 time
Post by Tsquared »
When did this problem start? Has it always done this? Are there any other electronic peculiarities that have happened or CEL codes? Are there any electrical modifications or additions (amplifier, radio, fog lights, security system)? And, does everything work in the car like it should once the car is running?
Just as an FYI these cars will do weird things when the battery is about to go out. This also may have something to do with the Starter Control Module but you should get some CEL codes for that.
'11 C30 T5
'96 854 - died an early death with 184K miles. Killed by the front end of an LTD on a suicide mission (T-boned and both cars totaled).
kranz
Year and Model: '98 V70 NA stick
Been thanked: 7 times
Post by kranz »
My '06 V50 also turns the headlights on. This apparently is normal operation, and IIRC it is in compliance with some set of auto regulations/standards. Turning it off was not a menu option and I believe it would require a firmware mod to make it go away.
Les is more.
