Good People,
Do I need a special holding tool for the crank/harmonic balancer to get this job done?
Thanks,
John Gregory
Portage, MI
2002 S80 2.9 Timing Belt replacement - Do I need a special tool?
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
I did not touch harmonic balancer during timing belt on 2001 v70xc. There was ample space for the belt to roll off and then back on.
precopster
- Year and Model: Lots
- Been thanked: 128 times
The 6 cylinder S80 is basically the same as a 5 cylinder motor in timing procedure. The CVVT just needs to be setup at clockwise rotation with no anti-clockwise rotation during belt attachment. If you go clockwise without belt attached just wind the cam pulley anti-clockwise 30 degrees then back to the timing mark.
- 8649 Views
Last post by Eric66
- 1127 Views
Last post by FCPEURO
- 1538 Views
Last post by moose1
- 1436 Views
Last post by skunkd84
- 1815 Views
Last post by chaos26670
