Passing emission test: iPD flash vs ARD and others
biohazrd76
- Year and Model: 1997 850R
Are any of you using an ard tune, what level and size turbo? I have an ipd stage 1 tune, my car has to pass emissions.... I don't know if a major tune will pass the tests. Smoke test that is.
Reason: Clarified title
1997 850 R, black.
Ipd HD tcv, msd coil pack, ipd HD cbv, ipd stage 1 ecu flash, iridium plugs,heavy gauge plug wires, airbox cover delete, k&N cone filter directly before maf, ipd HD end links.
Graveyard: 1993 850 glt, NA 168 bhp,gold. Hit and run 2009 totaled
1995 850 Turbo, 222 bhp totaled
precopster
- Year and Model: Lots
- Been thanked: 128 times
If the test is at idle it will have no bearing whatsoever. Only when extra boost is called for does a tune/bigger turbo come into play. Parameters for extra boost are load and torque demand on the ME7 system. At idle nothing is changed.
If your car doesn't pass emissions do a Stage 0 maintenance and see if it flies after that. If your airfilter looks old/dirty remove it for the test.
- 24 Replies
- 11139 Views
- 1520 Views
Last post by 1998-S90-Owner
- 1000 Views
Last post by cn90
- 53 Replies
- 8354 Views
Last post by theWIFES_S70
- 2841 Views
Last post by Oly850
