1995, Volvo 850, NA, Cabin Odor
For the last 6 months I have been getting some fumes in the cabin that to me smelled like exhaust gas. The fumes can be a bit overwhelming at times so I brought to it my custom exhaust shop and had them check it for an exhaust leak, and none were found. They thought the fumes might be related to the fuel vapor recovery system. To me it smelled like exhaust, not fuel. I drove it a couple more times and didn't notice and odor, so I wonder why it is intermittent. Any similar experiences out there?
2008, C70, 44,000 miles
2000, S70, GLT, 67,000 miles
1995, 850, GLT, 144,000 Miles
1996, 850, Turbo, 226,000 Miles (TMU)
volvofornia
- Year and Model: '94 850 T5
Hi, I bought a '94 850 two weeks ago and I had the same feeling after I drove around the first days. I couldn't find any exhaust leaks so far but I fixed a couple of things which maybe also fixed the odor problem.
What I did so far:
- I checked the EVAP system of leaks and had one at the roll-over valve (next to the fuel filter)
- I also replaced most of the hoses cause lots of them where old and had leaks
Since then I don't smell exhaust or fuel fumes inside anymore.
Don't know if that helps but I wanted to let you know.
Best
What I did so far:
Best
'94 850 T5 - 150k Miles - hopefully soon daily driver
benpineapple
- Year and Model: '06 V50 T5, '13 XC90
- Has thanked: 5 times
- Been thanked: 4 times
I agree with volvofornia, likely EVAP leak
Might as well check other vacuum lines while you're at it. If it has an EVAP leak, it's likely a lot of other hoses are cracked and leaky as well.
2006 V50 T5 [190,xxxM]
2013 XC90 FWD [80,xxxM]
2001 V70 X/C AWD [sold at 120xxxM],1998 V70 AWD [RIP at 249,255M], 1990 240 [SOLD at 220xxxM]
volvofornia
The PCV emissions smell more "sweet" (hard to describe it) compared to fuel/exhaust fumes. I would start with checking the complete EVAP system. Let us know about the outcome.crlande wrote:PCV system? venting from dipstick or the hoses could enter thru fresh air vents.
Thanks! Might be a little while before I get to check it out. As soon as the weather improves I'll take a look. I'll be sure to post my findings.
