All right, I'm half way through changing my PCV but I got stuck on how to replace the fuel line from the injector rail.
On other pics there are some nuts and bolts which connect the fuel line to the rail but in my case it's just one line going into the rail. So what to do now?
Any ideas?
850 // How to disconnect the fuel line?
volvofornia
- Year and Model: '94 850 T5
- skloon
- Year and Model: 94 850 95 850 04 S60
- Been thanked: 2 times
there should be a torx screw holding a little u like clip the screw is under the fitting- undo screw-remove bracket and don't drop into enginge compartment wiggle fitting free
volvofornia
See it. It stuck though. Might use pblaster first.
'94 850 T5 - 150k Miles - hopefully soon daily driver
tryingbe
- Year and Model: None
- Has thanked: 1 time
- Been thanked: 26 times
There is no need to disconnect the fuel hose. Just undo the two T25 bolts, one on top of the engine and one on the back of the engine and move the rail with the injectors out of the way.
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
volvofornia
I did that. Thank you
- 1926 Views
Last post by Goldchemist
- 559 Views
Last post by Georgeandkira
- 2420 Views
- 351 Views
- 1230 Views
