Had a shop replace the struts and they didn't install the spring seats. We are rural so not a dealership. I have the parts and a decent shop (farm shop so tools and such) but can't seem to find any tutorials or how to ' s on just installing the spring seats. Any help, advice, links, etc is appreciated. What special tools will I need, normal pitfalls, etc.
Thank You for the help.
02 S60 Spring Seat replacement help
- jeffriehunter
- Year and Model: 2002 S60 2.4T
- gmh
- Year and Model: 2016 XC60 T5
- Has thanked: 28 times
- Been thanked: 22 times
Hi, welcome to MVS. Here's a few links I think will help. Unfortunately you have to remove the struts and use a spring compressor to change the spring seats. The links all pertain to 850's or V70's but I think the procedure is the same.
https://www.matthewsvolvosite.com/forums ... =1&t=28455
https://www.fcpeuro.com/products/volvo- ... em-vfsk2-t (scroll to bottom of page)
http://members.shaw.ca/heeeeee/strut/
Gary
1969 145S (1987-91)
1973 145E (1989-90)
1981 245 (1990-2001)
1981 244 (1991-2002)
1989 760 Turbo Wagon (1999-2011)
1994 850 Turbo Wagon (2002-2013) burnt valve
2001 V70 2.4T (2009-2017) sold
1997 850 R Wagon (2013-2025) sold to Matthew
2014 XC60 T6 (2017-present)
2016 XC60 T5 (2024-present)
1969 145S (1987-91)
1973 145E (1989-90)
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
As mentioned, once the strut assembly is removed from the car, you will need a spring compressor because the spring is under tremendous pressure. Read a little on internet and make sure to install properly the two rods of the spring compressor so as to create even compression. Shops sell this compressors for not much, I won't suggest getting the cheapest thought.
If they did not install the 'cross' shaped nut on top of the spring seat you will need one of these as well.
When the strut is out of the car, look above inside the chassis where the strut bearing plate is seated, this place tends to rust quite a bit. A little rustproof paint is a good idea.
- gmh
Some of the big chain auto parts stores (I got mine from O'Reilly's) lend spring compressors and other rarely used but pricey tools. You pay a deposit that is refunded when you return the tool the next day. Worth checking out if there are any big chain stores nearby.
Gary
1969 145S (1987-91)
1973 145E (1989-90)
1969 145S (1987-91)
1973 145E (1989-90)
- Has thanked: 311 times
- Been thanked: 817 times
On a P80 car (850, x70), alignment is not necessary after pulling the struts, but not a bad idea. If the 02 S60 is similar then the only adjustment is toe, and you don't affect that on a strut job. As insurance you can mark the positions of the two bolts at the strut to steering knuckle, and/or on reinstall just pull the bottom of the strut outward before you tight those two bolts.
- 3844 Views
Last post by 98v70dad
- 2203 Views
Last post by Cookie-the-Swede
- 69 Replies
- 12153 Views
Last post by enotslim
- 1029 Views
Last post by LOB
- 985 Views
Last post by E Showell
