02 S60 vacuum hose and turbo vacuum hose routings?
- jeffriehunter
- Year and Model: 2002 S60 2.4T
When we replaced the head gaskets on this one (did that in home shop) I am not sure we got all the vacuum hose and turbo control hoses (the small ones) all routed correctly. I haven't been able to find a good diagram anywhere. And suggestions or routing guides available??
- jeffriehunter
I will check.....would it be under the insulation material?
- Has thanked: 1613 times
- Been thanked: 4078 times
Visible on my P2 way up near the driver corner of the hood. If you stand in front of the engine with the hood up you can't see it. You have to stick your head in from the side and turn sideways
- jeffriehunter
Well hush my mouth sparky65!! There is a diagram there.....in all of our work on this car I somehow never saw that....what a great help!!
THANK YOU!!
THANK YOU!!
- jeffriehunter
You have to laugh....I had never noticed it before. It was very helpful once we found it thanks to the forum and abscate!
Now that you found it you have to check that it's the right one..
- 3926 Views
Last post by MarcM
- 3087 Views
Last post by greg850r
- 690 Views
Last post by tryingbe
- 1602 Views
Last post by southofmotown
- 12 Replies
- 3505 Views
Last post by polskamafia mjl
