trouble codes
Mike Langlois
Year and Model: 2002 V70 & V70 XC
Has thanked: 28 times
Been thanked: 6 times
Post by Mike Langlois »
I have a 2002 V70 X/C 2.4 AWD turbo that has had a major service. WE replaced the complete PCV system (Use factory parts), radiator, flushed and replaced ALL fluids and replaced just about everything else that wears out at 150k miles. I am a Little neurotic about cleaning, so all the Throttle bodies, intercoolers, tubing and such have been cleaned and replaced. I still have a few trouble codes and wonder if anyone knows what they are:
P2096 post catalyst trim system too lean bank 1
P0507 Idle air control system rpm higher than expected
P0504 Brake switch A/B correlation
P0501 Brake switch A circuit
I need to identify and fix the first 2 trouble codes in order to pass smog in CA
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
JeffHicks
Year and Model: 1989 240 Wagon,
Post by JeffHicks »
My first hunch would be to check all your vacuum lines.
1989 240 Wagon, 1999 V70 Base, 2002 XC70, 2005 V70 T5
