Following rain, the passenger side floor gets water. I had assumed that leak comes from top of windshield. Bought and applied clear silicon three times but water has continued to appear in same area - only the front passenger floor. No other part of vehicle gets wet.
Should I be looking to replace windshield? There is black stripping at the top of windshield that needs to be replaced. Does anyone know where to purchase that, as well as, the stripping which runs at both sides atop the car?
Could it be anything other than the windshield?
Thanks.
Water Inside '95 850
- Has thanked: 2207 times
Does the car have a moonroof?
There have been a couple of threads recently on the same subject with several suggestions on where to check.
biohazrd76
- Year and Model: 1997 850R
My 95 did the exact same thing. Here's the fix.
Number one, the vehicle is sensitive to being parked nose downhill, this made mine leak worse, #2 the moonroof tends to close too far if you hold the switch until the motor stops. I found that making sure the window comes to rest Completely flush with the surrounding gasket is very important to keeping your Volvo dry. There are no over the counter sealants that can be applied over top of ANY part of your glass that will reliably stop water. This is a job for a pro. So don't waste your money or ruin your paint(more importantly)
1997 850 R, black.
Ipd HD tcv, msd coil pack, ipd HD cbv, ipd stage 1 ecu flash, iridium plugs,heavy gauge plug wires, airbox cover delete, k&N cone filter directly before maf, ipd HD end links.
Graveyard: 1993 850 glt, NA 168 bhp,gold. Hit and run 2009 totaled
1995 850 Turbo, 222 bhp totaled
rafmarkham
- Year and Model: 2004 VOLVO V70 2.5T
I had the same problem with our '95 850 Turbo wagon years ago, and it turned out to be a cabin filter issue. The filter was crudded up with dirt, leaf matter, etc. and had blocked the drainage tube. Easy solution: filter replacement after clean-up, and removal of water under floor mats, solved the problem in my case.
You can easily replace the filter from the outside, with the hood open, after taking out torx screws securing the black plastic between the windshield and engine compartment, under the wipers. Don't lift the wipers up before you start - they may damage the hood. Sliding the plastic shield forward,or lifting the right-hand side out of the way, allows you to pull the old filter out. Make sure the area beneath it is cleaned out, and that the drain tube is not clogged. Replacing or checking the filter may have to be part of a routine if parking where leaf debris accumulation could be an issue.
Trust this helps - and hope it avoids more drastic windshield sealing strip or moon roof work.
2004 V70 2.5T 192,000 km
1998 S70 200,000km
1995 850T wagon 440,000 km
(Drowned Lima,OH July 2015)
1991 Mercedes 300E 174,000km
1991 Mazda Miata
1974 MGB 139,000 km
Lady Leadfoot gets the 2015 Edge
1998 S70 200,000km
1991 Mazda Miata
1974 MGB 139,000 km
- 891 Views
Last post by Brentscrazyptwo
- 1666 Views
Last post by cn90
- 12 Replies
- 7572 Views
Last post by viper69
- 5083 Views
Last post by kallekula
- 5170 Views
Last post by darrylrobert
