94 850T Codes
mta58
Year and Model: 1997 850 GLT
Post by mta58 »
I recently went to Advance Auto and the following codes popped up for my 94 850 Turbo.
P 0402 EGR Flow Excessive
P 1417 Manf Ctrl Aux Emission Ctrls
P 0326 Knock Sensor 1 Ckt Range/Perf, Bank 1 or Sensor 1
P 1505 Manf Veh Spd, Idle Spd Ctrl, Aux Inputs
P 1507 Manf Veh Spd, Idle Spd Ctrl, Aux Inputs
I replaced the EGR and would like to know where the main problem lies & how can I fix it. I'm not aan experienced person but it seems to be either an MAF Sensor problem because the car will not idle smoothly without high revs (2,000 - 3,000 RPM).
Any help would be appreciated.
Thanks so much & I love this car !!!!
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
You were able to read your '94 850 diagnostic codes at AutoZone? It has an OBD port? I would again read your codes from the black diagnostic boxes under your hood and see what the Volvo specific codes are. I'm a bit surprised as I've never seen a '94 with an OBD port.
This shows you where the diagnostic boxes are:
http://www.volvospeed.com/850slight.php
This shows you the diagnostic codes for Transmission/Engine, etc:
http://www.volvospeed.com/maintence.htm#Lights
(DTC Codes...right under the upper heading)
bryang
Post by bryang »
MadeInJapan wrote:You were able to read your '94 850 diagnostic codes at AutoZone? It has an OBD port? I would again read your codes from the black diagnostic boxes under your hood and see what the Volvo specific codes are. I'm a bit surprised as I've never seen a '94 with an OBD port.
I have a 94 850 as well, the OBD port is in front of the gear shift, to me it looks like a coin holder but you can pop it off and below it is the port where the reader plugs into it.
1994 850 Turbo Wagon - 218,000 Miles
Luther White
Post by Luther White »
I too have a 94 854T and it also has an OBD II port although I have never used it, just use the diag...box under the hood.
Luther White
1994 Volvo 850 Turbo
170,000 miles
Interesting...had heard of a few '95's with OBD-II ports, but not '94's.
Des
Post by Des »
Yes,I have 94 turbo st.wagon.I have obd ll cod reader on my Volvo.This car is overloaded with electronics and sensores,Des.
wallie
Post by wallie »
I have a 94 855T with the OBDII port also but I've been reading codes under the hood. Has anyone been able to get any useful info from the port on a 94?
Wallie
mta58
Post by mta58 »
Dear Everyone:
This is not the official OBDII/Code reader post.
As an update, I replaced the Idle Speed Motor and finally the MAF Sensor. When the MAF was replaced, the CEL light went out and now only the service light is on. I am taking the car to an auto mechanic in Atlanta close to our house to find out why it still won't idle normally. My best guess is that a vacuum hose is misconnected when I replaced the EGR. You must remove a lot of hoses and other devices to do this and I must have done something wrong although everything seems to be in it's proper place.
Will keep eevryone updated. :)
