Is there a date code on volvo timing belts
fairmont50
Year and Model: 1999 v70r
Been thanked: 3 times
Post by fairmont50 »
I have purchased a replacement engine for my v70r and need to know if there is a date code on the belt that would determine if the timing belt has been replaced? The timing belt has a volvo part number but no obvious date code.
Thanks
Chirs
Has thanked: 1609 times
Been thanked: 4063 times
Look all around the engine compartment for a sticker. How many miles are on it? If the engine isn't in yet it is a cinch to replace with it out.
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
When in doubt, replace the TB, tensioner and idler pulleys. The TB kit is $120 from Volvo online (not from local Nebraska dealer, who set its own price!).
fairmont50
Unfortunately, I only have the engine, not the car (there was no timing belt sticker on the timing cover). I was hoping to avoid the $200 cost of a timing kit is it has already been done. At 150000, the engine is overdue for a belt if it has not been done yet.
Chris
This may end up being a double post.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
If you are replacing the engine and plan to keep the car, why risk the belt, water pump, etc. It's to easy to replace out of the car. A belt is about $30. If your stuff was good, you can use it for another 50,000 miles.
fairmont50
If there is no date code on the belt (and it appears that there is not), I will replace the belt, pulleys, tensioner and water pump. I was just hoping to avoid that if possible.
Chris
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
It should be....my Volvo belts have a date of manufacture on them.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
