I have a 00 S80. I bought this at auction drove it home and took the key out and it keeps blowing air... until the Battery drains:
- IT BLOWS AS LONG AS BATTERY IS CONNECTED UNTIL DRAINED
-IT BLOWS EVEN WHEN HUMIDITY IS LOW AND OUTSIDE TEMP IS LOW
- WITHOUT KEY INSIDE IT STILL BLOWS
- REPLACED THE BATTERY NEXT DAY AS SOON AS WIRES CONNECTED IT TURNED ON AGAIN AND PROBLEM CONTINUES
- WHEN ON THE TEMP IS MID GAUGE AND NORMAL
I have cleaned the MAF SENSOR
any ideas?
00' S80 cabin fan blowing till battery dies
sweetwheel
- Year and Model: 2000 s80
Reason: Clarified title - please, no CAPS in titles - read the rules
kahl
- Year and Model: 2000V70XC
- Been thanked: 10 times
My 2000 S80 started doing the same thing about two years ago. Could not figure out why, but other owners have had the same problem. I took it to the Volvo dealership and they installed the latest software into the ECU. The problem stopped. This worked for my S80 get use to having oddball items creep up that will have you banging your head against the wall.
sweetwheel
ill call the service center on monday and ask them about that thanks kahl.
I was reading it could be a symptom of a bad blower motor resistor. So i checked to see if the ac fan ran on any other speeds and while i could change the temp , the fan would only run on high. Currently I removed the resistor and found corrosion on the metal plate ... i have a multimeter but cant find the normal resistance specs for the s80 blower motor resistor (made by behr).
Well see what they say at the service shop ill have them test it for me.
sweetwheel
So Final answer
needed to replace my climate control module to take care of constant blowing
and had to change the blower motor regulator to take care of te speed issure
- 1199 Views
Last post by ggleavitt
- 1961 Views
Last post by cmarcoux
- 1118 Views
Last post by James_A_Sousa
- 1980 Views
Last post by alschnertz
- 370 Views
Last post by Lukieb
