IPD sale Volvo Parts
2008 S80 T6 code P0171, PCV issue?
Help, Advice, Owners' Discussion and DIY Tutorials on the current (third) generation Volvo V70 wagon and XC70 crossover, and second generation S80.
This is a forum for owners or prospective owners of the third generation V70, second generation S80, and its siblings built on the EUCD platform.
VCA
Year and Model: 2008 S80 T6 AWD
United States of America
Post by VCA » Sun Jan 17, 2016 4:13 pm
Good day MVS!
I've got an '08 S80 T6 with its first 'I'm stumped' problem. I'm getting an ECM-P017100 (system too lean). It's too lean in bin 1,1 (idle basically), with the long term fuel trim going to 1.30 in that bin, but with all others being right around 1. No obvious vacuum leaks. However, I noticed vacuum at the dipstick that makes a sucking sound when pulling the dipstick. I see the Volvo test shows that crankcase vacuum should be between -0.2 and -0.5 kPa. I'm getting -2 in Hg of vacuum (-6.7kPa) at the dipstick. I also notice an oil 'scunge' in the vicinity of the oil separator's pipe that goes to the intake pipe that feeds the turbo. Does this mean what I think it means (failed oil separator)?
Any other things I need to look at on this car? I've checked all the obvious piping with no results.
Thank you!
2008 S80 T6 AWD
1999 S70 GLT
Responsible for the care of a '92 960 and an '07 S60R
VCA
Re: 2008 S80 T6 code P0171, PCV issue?
Post by VCA » Mon Jan 18, 2016 6:48 pm
OK, so the oil trap was bad for sure. There was a vacuum leak at the little hole that the membrane uses for its pressure reference. New oil trap installed today and no more leak there, as well as significantly less crankcase vacuum...there's definitely a vacuum, but it's not 2 in Hg of vacuum, it barely tips my vacuum gauge into the vacuum range now (0.5 kPa vacuum is about 0.14 in Hg)...perfect. However, after resetting adaptives and test driving, the adaptives for area 1,1 are at 1.11 and I suspect climbing...so I still have an air leak somewhere. *&%$#@! Help?
2008 S80 T6 AWD
1999 S70 GLT
VCA
Post by VCA » Tue Jan 19, 2016 8:21 pm
OK, so I just wasn't patient enough: the long term fuel trim went up to 1.14 after a long drive today and later came down to 1.12 after a drive. All's well.
Lesson learned: high vacuum at the dipstick might be just as obvious a sign of PCV failure as no vacuum at all...at least on P3 cars.
2008 S80 T6 AWD
1999 S70 GLT
Jabber5
Year and Model: '06 XC90, '08 S80
Post by Jabber5 » Wed May 09, 2018 8:57 am
I have the same year, same model, same engine, same code. How did you figure out that the leak was coming from the oil trap?
ndphotonl
Year and Model: S80 2.4T Wasa
Has thanked: 13 times
Been thanked: 15 times
Netherlands
Post by ndphotonl » Tue Sep 25, 2018 8:58 am
1.14% LTFT is awesome, good job.
Volvo S80 2.4T Wasa Limited Edition
Blog / FlickR / YouTube channel
pierremcalpine
Year and Model: V40 2003, V70 2010
Canada
Post by pierremcalpine » Wed Sep 26, 2018 5:24 am
Thank you for sharing! Very helpful.
Who is online
Users browsing this forum: No registered users and 4 guests
