Do coils slowly die, or quickly die?
JeffHicks
Year and Model: 1989 240 Wagon,
Post by JeffHicks »
General question, but it's because I'm still tinkering on my '04 V70 T5.
Do the ignition coils on these Volvos ever just "slowly die" - as in, low spark, random misfire, slowly fading out? Or do they just stop working altogether - specifically, either on or off?
1989 240 Wagon, 1999 V70 Base, 2002 XC70, 2005 V70 T5
harryhendo
Year and Model: 940, 855, S70, V70
Post by harryhendo »
In my experience, they start to fail intermittently and fail completely over a period of time. For example, on my 2002 V70, the engine started stumbling a bit on hard acceleration, then after a longish road trip, started to fail even at cruising speeds, then it became evident even on idle about a week later. The best way to diagnose this is to get an OBD-II code reader, and, if you get a misfile code (0301 would be misfire on cylinder 1, 0302 on cylinder 2, etc.), swap the misfiring cylinder's coil to another cylinder and see if the code follows to that cylinder/coil.
'92 940
'94 855 (manual!)
'00 S70 (manual, the $500 experiment)
'02 V70
JeffHicks
Post by JeffHicks »
^ I got P0303 & P0304 codes, as well as the generic P0300. I swapped out 3 & 4 with used Volvo coils I got at a salvage yard. We'll see what happens.
JeffHicks
Post by JeffHicks »
Follow-up question:
Have any of you bought non-Volvo coils and been happy with them? Bosch? Other? Does IPD sell anything but Bosch?
harryhendo
rockauto sells non bosch coils and I've never had a problem with them. Very inexpensive too (< $40).
'92 940
'94 855 (manual!)
'02 V70
harryhendo
Be aware that the misfire codes may be caused by other problems than just a failing coil, so just replacing coils may not solve the issue. Isolating the misfile by swapping around coils and sparkplugs is a good procedure to follow.
'92 940
'94 855 (manual!)
'02 V70
JudgeRat
Year and Model: s60 2004
Has thanked: 3 times
Post by JudgeRat »
The simplest answer is: Yes - meaning that they do both; sometimes they fail intermittently and sometimes they just fail outright. The advice to swap the coils/plugs is dead on too. I'll add that it could also be something in your wiring so you might want to test it too.
"Molly" - Black 2004 2.4L i5 (non-turbo) T5 Auto FWD P2 Volvo s60 w/all options
Old-school race guy: "Brakes 1st, then steering, tires, wheels, & suspension, only then engine and drive-train. No sense making it go if you can't stop & steer properly...Safety first people!"
mouseskowitz
Year and Model: '02 and '04 V70
Post by mouseskowitz »
I had one coil pack die on me suddenly and replaced it with a Delphi with no problems to date, maybe 20k miles. $36 on Amazon. When I started having misfires on two cylinders during startup a week or two ago I realized the plugs hadn't been replaced since I bought the car 60k ago. New plugs have fixed that issue so far.
2002 V70 2.4T ~202k miles
2004 V70 2.4 ~92k miles
Has thanked: 1609 times
Been thanked: 4063 times
I had one fail a week after a school bus jump pack start. I think the two events were correlated but not certain.
Originals about 120k miles or so, 10 years old
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
Ignition coil is basically a transformer that converts 12V into 48,000 volts (or something like that).
So it can fail intermittently (shorting across the copper windings) or suddenly.
This is why when we drive cars of this vintage, it is a good idea to buy a 5-pack of used coils on ebay (check what you have in the car before buying used coils to be sure they are the same) or junk yard for cheap. Usually it is around $10-$15/coil. Keep some in the trunk, it could save a bad day.
