I have a UK spec S80 T6. Ive done the transmission flush, and replaced the radiator after finding ATF in the coolant. The car now seems fine, but will cut out as if the ignition has been switched off, and does it without warning, usually when slowing down It has been known to do it at idle, too. It restarts straight away and runs normally. This can be exciting, to say the least, especially at junctions. If you're travelling at normal speeds, it will miss one beat, then keep going.
My inexpert suspicions are aimed at the aircon, as it used to hunt on startup if the aircon was switched on. It only does this if the aicon is on, so I'm assuming it's connected in some way. Any ideas, guys?
Many thanks for taking the time to read this,
Steve.
Random cutting out, possibly Aircon issue?
Cees Klumper
- Year and Model: 2002 S80 T6
- Has thanked: 46 times
- Been thanked: 33 times
According to his post it's a T6.
- 5549 Views
Last post by SwissXC90
- 641 Views
Last post by HarryS
- 12 Replies
- 2883 Views
Last post by ferocity02
- 1912 Views
Last post by ElVee
- 685 Views
Last post by jreed
