Has anyone tried to use this 10-in-one tool to reset the SRS light on a 1996 850 Turbo, and is there another cheaper way to do it?
http://www.ebay.com/itm/271461793804?item=271461793804
How can I reset the SRS light on a 1996 850 Turbo?
- Has thanked: 311 times
- Been thanked: 817 times
Haven't tried it, don't know about that one.
Cheapest easy way to reset SRS yourself is VOL-FCR and the PC laptop you already own (obviously not the cheapest if you don't have a laptop
). You only have to pay about $15 for a cable.
There are also code readers that can do it but they are not cheap. Unless you can borrow one, then it might be free to reset it!
- Has thanked: 2197 times
- Been thanked: 1850 times
Unfortunately I don't know this unit, and it doesn't say what Volvos it works for. Might want to find out if it is suitable for your needs, as 98 and older use a different software. Erik's suggestion is good, and there is a section for the tools on that. There are some of the cables that can be bought that come with the vol-fcr software and then can be fixed from a laptop. There are some free versions also.
I have a tool for this I bought in the UK, but they are very hard to find and expensive.
esl_97_850_T5
- Has thanked: 18 times
- Been thanked: 27 times
robocam,
Another potentially cheaper way compared to the 10-in-1 tool is: volvo850diag / Realterm / IE / Windows and a KWPD3B0-capable ELM327 tool.
On 2016-01-22 someone used volvo850diag (free) / Realterm (free) / IE8-WinXP ($??) and a ScanTool.net OBDLink SX (~$30) to reset an 850's SRS DTC 07 -- otherwise known as "SRS-222 -- Passenger Airbag open circuit (in SRS harness, connector, or airbag)".
The jonesrh.info server logs indicate that SRS DTC was successfully cleared, then remained cleared till ~2 minutes later when the SRS DTCs were read again during the Read All DTCs function.
volvo850diag should also work with Win7/IE11, Win8.1/IE??, Win10/IE??.
esl_97_850_T5
esl_97_850_T5
1998 Volvo S70 GLT - 205.5K miles - S70 & M44 testbed in 2016-2019; traded 2019-07-15 (for spare time)
1997 Volvo 854 T5 - 147K miles - 850 testbed in 2012-2017; junked 2017-09
- 8975 Views
Last post by spue
- 1868 Views
Last post by precopster
- 1833 Views
Last post by vtl
- 12 Replies
- 4534 Views
Last post by pfmet
- 27 Replies
- 27311 Views
Last post by cn90
