04 V70 Fuel Pressure Sensor/Regulator Location
JeffHicks
Year and Model: 1989 240 Wagon,
Post by JeffHicks »
There is no fuel pressure regulator/sensor on the fuel rail of my '04 V70 T5. Just a schrader valve on one end.
Where could the sensor/regulator be located?
1989 240 Wagon, 1999 V70 Base, 2002 XC70, 2005 V70 T5
harryhendo
Year and Model: 940, 855, S70, V70
Post by harryhendo »
The regulator is the flying saucer shaped silver part that attaches to the underside of the fuel rail between the #1 and #2 cylinder's injectors.
'92 940
'94 855 (manual!)
'00 S70 (manual, the $500 experiment)
'02 V70
JeffHicks
Post by JeffHicks »
harryhendo wrote:The regulator is the flying saucer shaped silver part that attaches to the underside of the fuel rail between the #1 and #2 cylinder's injectors.
It is not on this fuel rail.
I have the fuel inlet, the 5 injectors, and a schrader valve. NOTHING else.
harryhendo
Then it must be inline to the fuel line running from the fuel pump. You have me stumped about location.
'92 940
'94 855 (manual!)
'02 V70
Has thanked: 1609 times
Been thanked: 4064 times
It isn't regulated by vacuum like the older cars. I believe the flying saucer is a damper, not a regulator.
I think the pump delivers 50 psi to the rail unregulated from ME7 engine management on.
JeffHicks
Post by JeffHicks »
abscate wrote:It isn't regulated by vacuum like the older cars. I believe the flying saucer is a damper, not a regulator.
That's the only thing I can figure. There is no pressure sensor/regulator. There is no fuel pump control module (apparently they put those on the steel gas tank models). The only thing left is for the pressure to be regulated by the pump.
