I spent the past couple of days trying to install Vida 2014B on my Windows 7 Ultimate laptop, and got everything loaded properly only to have the program get stuck at the "localhost" page. After trying all sorts of other things that made no difference, I finally discovered that this version of Vida isn't compatible with IE 11- I had to uninstall IE 11 (which you do through the control panel, look at "view installed updates" and you can uninstall Internet Explorer from there) and then reboot, and install IE 9 (make sure you've downloaded it first unless you also have Google Chrome or Firefox!). So far Vida is working like it should. I haven't connected DICE yet, but I will do that in the next few days and will report back with what I learn. My understanding is DICE needs a 32 bit version of IE 9, and mine is 64 bit so I may have some more figgerin to do.
Just thought I'd put this out there for you folks who might be struggling with the same issue.
Installing Vida 2014B on Windows 7 Ultimate not compatible with IE 11
turtlehead
- Year and Model: 98 Volvo T5
- Has thanked: 1 time
- Been thanked: 2 times
- Has thanked: 2199 times
Had the same problem, except it was with a downloaded backdate to IE8. With help eventually got it running with IE9. Only issue I have is with trying to read the repair info. It won't let me scan down the page. If I put it into PRINT mode I can then usually read the information.
Neil
Neil
- 2012 Views
Last post by MrAl
- 28 Replies
- 64928 Views
Last post by jonesg
- 3228 Views
Last post by packetfire
- 3288 Views
Last post by tmcmilli
- 2714 Views
Last post by Williamad33
