Unable to find fuse/s for Low Beams?
JimmyXi
Year and Model: 2008 V70
Post by JimmyXi »
2008/V70 .. Dummy here was fooling around with alternative bulbs in my low beams ..the things (LEDs) worked OK ..'till it got dark: LEDs output are like AAA, filament flashlights. (with a pretty color but no lumens) Maybe great for Paris or NYC, but not the boonies. Put the working stock bulbs back in: Ooooops! No low beams? I have High Beams and the little bulbs in the center... so the connectors/harness is likely Ok, yes?
Pull out the book ...hmmmm, no fuse for LBs? (one for HB under glove box) Called dealer (2hrs distant) and asked about fuse/s. Svc. Mgr. says; "There are two each (fuses) for High and Low Beams." (guess he didn't read the manual..) 2hrs. (really 4) drive is too much if it's something simple. So I humbly ask for some advice. Thanks.
Jim
