Evening,
I have no current to my passenger side low beam (driver side is ok.). I read in one thread that there is a "right" and "left" fuse but according to fuse chart that doesn't appear to be correct, unless I am missing something. In any event, all fuses in the engine bay are ok. So rather than tearing the front apart to get the light out and maybe, maybe not, finding the wire problem, would it be ok to tie into the other low beam wire? If I do, would I be overloading that wire, now feeding both lights with it?
Thanks,
Emil
No power to one of the low beam
..and now you have prevented many from the same error....Thanks for the illumination of your problem.
Duncx
- Year and Model: V70 2.5t AWD 2005
For forks sake .... friend's S60 had left headlight out and she had bulb replaced (was actually blown) and still no light. I had a look and no power to it.
Thanks for the pointer
- 1585 Views
Last post by mrbrian200
- 801 Views
Last post by BEJinFbk
- 3546 Views
Last post by 93SCMax
- 2042 Views
Last post by Ozark Lee
- 1632 Views
Last post by shanegtr
