Hi All
New Volvo owner and I'm trying to troubleshoot bad ETS light. I wanted to check on and clean my MAF and when I pulled it out and checked the part number it seem like it's different than what FCPEUro specifies for my year/model so I wanted to double check with you folks. There is a chance that the previous owner put in the wrong MAF...I have a 1999 v70-XC Turbo
I have the Bosch 0280218045 (Like I said, I don't know for SURE that is the correct part for this car).
FCP tells me I should have the 0280218108
Is this a question of a new part number for the exact same thing? Is the MAF (last 3 digits) 108 the same as the MAF 045?
thanks,
Steve
Correct MAF for 1999 v70-XC Turbo
- gmh
- Year and Model: 2016 XC60 T5
- Has thanked: 28 times
- Been thanked: 22 times
This item on Amazon indicates that they are both for that car.
https://www.amazon.com/Bosch-Mass-Sensor ... automotive
Gary
1969 145S (1987-91)
1973 145E (1989-90)
1981 245 (1990-2001)
1981 244 (1991-2002)
1989 760 Turbo Wagon (1999-2011)
1994 850 Turbo Wagon (2002-2013) burnt valve
2001 V70 2.4T (2009-2017) sold
1997 850 R Wagon (2013-2025) sold to Matthew
2014 XC60 T6 (2017-present)
2016 XC60 T5 (2024-present)
1969 145S (1987-91)
1973 145E (1989-90)
JRL
- Year and Model: Several
- Been thanked: 16 times
ETS light does not come on for a bad MAF
You probably need a new/rebuilt ETM (throttle)
Ringo
- Year and Model: 2006 70XC
- Has thanked: 33 times
Thanks guys. Yes, I've done reading here and I'm sure that I need to replace the ETM. In preparation I just wanted to clean the MAF and noticed the existing part number was different from what was being spec'd currently. I just wanted to rule out that the previous owner's non-Volvo experienced mechanic had installed the right part.
thanks again
Steve
thanks again
Steve
2006 XC70 2.5T auto (B5254T2) 125K 2nd owner
1999 V70 XC 2.4T auto (B5254T) 250K Trans failed 2018
1967 122S 2-door auto (B18B) 125K (ex-wife got it 1991)
Matty Moo
- Year and Model: 850, 1996
- Has thanked: 1 time
- Been thanked: 30 times
Doesn't hurt to think about that, but once the ets light comes on that's your confirmation.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
precopster
- Year and Model: Lots
- Been thanked: 128 times
The older Bosch catalogues used to cross reference the 045s afew years ago. I think it also suits the Bosch ETA cars from 2002 plus though officially they use the 088s
These days the catalogue has been updated.
Ringo
I am not gettting any codes. Is that also "normal" that the ETS light comes on and comes back but gives no codes?Matty Moo wrote:Doesn't hurt to think about that, but once the ets light comes on that's your confirmation.
precopster
If you read with the right scanner there will be codes. If driving performance is normal and you haven't lost cruise control you probably have a six month window until it implodes.
- 1051 Views
Last post by volvobro
- 781 Views
Last post by misha
- 3187 Views
Last post by mctee
- 1894 Views
Last post by albertoVO5
- 26 Replies
- 6405 Views
Last post by ChadLee
