TRACS OFF light is on, ABS is not, 850t.
rguzz
- Year and Model: 1996 850 turbo
- Been thanked: 25 times
The ABS module was rebuilt within last 2+ years or so. TRACS OFF light came on and has been on a few months now, 96 850t. Is this a wheel sensor issue, something at the wheels otherwise, or electrical-switch problem? Where would you advise me to look next? Thanks.
- Year and Model: Many Volvos
- Been thanked: 76 times
Are you real sure that the tracks switch didn't get pressed? The only other thing I can think of is that the TRACS switch is bad.
Matty Moo
- Year and Model: 850, 1996
- Has thanked: 1 time
- Been thanked: 30 times
I've had the issue come up about 8 times but never with one of my own cars. The only definitive thing that has come along with it is a charging/battery issue or the TRACS switch. I've never been able to replicate it with any of my own cars, even when I've had a battery issue. I've never had a steady under/overcharge issue to try it out. Whatever causes it is obscure as it doesn't have any bearing on anything else.
Just that light won't trigger a code in the module either.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
rguzz
There is a P0331 knock sensor code that won't go away for long, and the TRACS light off has been on before and after the code. So maybe it is the switch, if I understand the advice above correctly. No manual manipulation of the switch itself seems to make a difference. So is the TRACS system functional with the light indicating system is off? Might be a silly question..
Probably not but since the ABS light isn't on I would guess that the ABS is working. The ABS actually does something but in reality the TRACS really only makes noise and gives the illusion that it is doing something. I have never had less wheel slip in snow with it on than it had without it. The biggest irritant that you will have is the light itself being on.rguzz wrote:So is the TRACS system functional with the light indicating system is off? Might be a silly question..
If I were you I think I would start by pulling a battery cable and see if it goes out afterwards. You will of course need to have your radio code handy before you remove the cable.
rguzz
Thanks, I will do exactly that. Then figure out how to pull the switch, swap one out if still persists and motivated enough. Service light is also on, so might be time to pull a couple of dash bulbs.
- 22 Replies
- 5800 Views
Last post by hausmeister
- 374 Views
Last post by rguzz
- 12 Replies
- 1879 Views
1999 S70 ABS/TRACS light on after resolder
by jlferreira » » in 850, S70, V70, C70, V70-XC 1992-2000 - 1 Replies
- 799 Views
Last post by jose456891
- 3739 Views
Last post by rguzz
