Does anyone have any experience with this system, how it works,how to turn it on/off, how to program it, does it need to be programmed.
Thanks in advance
1998 C70 alarm/level sensor
- Year and Model: Many Volvos
- Been thanked: 76 times
Are you asking about the coolant level sensor? There are many alarms on the car so a bit more specificity would be helpful.
If it is the coolant level then there is no programming. There is a magnetic float switch plugged into the bottom of the coolant overflow tank and a float inside of the tank that triggers it. Sometimes the float itself gets stuck and just smacking the tank with the palm of your hand will free it up. If the float is free and the harness is plugged in then about all it can be is a bad switch. The switch just snaps into the bottom of the tank and it is very easy to change.
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
I think he´s rather asking about the antitheft alarm which might have a level sensor (that goes off if you try to push the car on a towtruck or lift it up into the air).
1996 855 R,
2010 V70 D5,
2010 V70 D5,
benpineapple
- Year and Model: '06 V50 T5, '13 XC90
- Has thanked: 5 times
- Been thanked: 4 times
Is there a specific issue you are experiencing with it?
I had an issue for a time where I would unlock my 98 V70, and the "silent alarm" would go off, disabling the starter. Fault was traced to the lock button on a bad master window switch. Remedy (when silent alarm as active) was to unplug the lock button from the switch, close the door, and lock/unlock it with the key in the door. A fob would have worked I'm sure, but I don't have one.
2006 V50 T5 [190,xxxM]
2013 XC90 FWD [80,xxxM]
2001 V70 X/C AWD [sold at 120xxxM],1998 V70 AWD [RIP at 249,255M], 1990 240 [SOLD at 220xxxM]
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
Are you sure that you have that optional sensor?Racerxc70 wrote:Does anyone have any experience with this system, how it works,how to turn it on/off, how to program it, does it need to be programmed.
Thanks in advance
They seem pretty rare in the US.
benpineapple
My 98 V70 has it too. That's 2/100,000 confirmed.BEJinFbk wrote:They seem pretty rare in the US.
Racerxc70
- Year and Model: C70 1998 coupe
Yes I have it, the car had every anti theft device available when I bought it in 1998, this one in particular needed to be disabled if it was traveling on a ferry or boat, (it never has) it's located in the trunk on the right side behind a panel,it's a white plastic box with some sort of liquid in it attached to a bracket there is no problem with it that I know of but somehow in the last 18 years the electrical connector was unplugged or never plugged in I just don't know,( maybe it was pissing off the mechanic during a service) I just found out last month while cleaning out the trunk, and before I reconnect it, I want to know more about it.
Racerxc70
BTW the car color is Saffron metallic ( code 435 ) and it is fully loaded, moonroof,901 surround sound audio,4 speed auto trans, 2.3 liter HP turbo (upgraded CPU to add 50 hp) the works.
Thank you for all your comments so far
- Clemens
So you got 50 hp just from an ECU ugrade?
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- 3977 Views
Last post by ZootAllures
- 1889 Views
Last post by jonesg
- 2206 Views
Last post by Sailsman
- 516 Views
Last post by xanthefin
- 1422 Views
Last post by RickHaleParker
