Recurring 2-1-2 94 850
- skloon
- Year and Model: 94 850 95 850 04 S60
- Been thanked: 2 times
My 850 is throwing a 212 code indicating the front o2 sensor- this is a new sensor, I have checked all the vacuum lines which are also new, there is no elbow under the intake manifold but I do see reference that it can be caused by the fuel evap system- how do I check this ?
- misha
- Has thanked: 155 times
- Been thanked: 432 times
What brand is replacement sensor?
Are the numbers on it the same like from the old one?
Phase 1 850 up to '95 had two types of o2 sensors.Titania & Zirconia.Titania works on resistance and,the most usual one,Zirconia works on voltage difference and they are not interchangeable.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 2857 times
- Been thanked: 1332 times
Which brand sensor? Are you sure you got the connector clipped together well?
- skloon
No idea of the brand of sensor or number, to add to the difficulty I am running an RN swap with an ECU from a 95 manual turbo- the car runs fine just throws the code about every 50km
- misha
'95 should carry Motronic 4.3 and '94 should have Jetronic engine management.They are not interchangeable.
Hmmmm....i'm surprised the car even starts and run unless u.s cars had motronic management even in '94.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- skloon
I have used my 94 ECU as well I get the 212 plus another one for the missing transmission- the 95 was a Canadian car and everything looked identical to my 94 except no EGR -which has been deleted and all the holes filled
- skloon
I am getting the error from A2, the TCU has been removed as it has been manual swapped, I am using the 95 ECU as it was a manual turbo car- and was 4.3 as is mine I do have a 4.4 ECU from a manual but it was a lpt so I don't want to use that
- misha
Don't use 4.4 in a 4.3 car without some wiring modifications.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
tryingbe
- Year and Model: None
- Has thanked: 1 time
- Been thanked: 26 times
Negative. No wiring modification needed anymore.misha wrote:Don't use 4.4 in a 4.3 car without some wiring modifications.
http://m44.wikia.com/wiki/M4.4_A/C_Converison
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
