Hello everyone.
I am having a problem with the door lock, the key doesn't lock or unlock the door but remote does. The problem is the driver door is the only door that has a key insert. Do you think this is an easy fix? My concern is that if the battery dies and remote doesn't function, is there any way to unlock the doors or pop up the hood?
Thanks.
Key doesn't lock or unlock but remote does-02 V70
neworleans
- Year and Model: 2007 S60R
- mydamnvolvo
- Year and Model: Lots
Your ignition may have been replaced if you bought the vehicle second hand. Then, there would be a key for the door and a key for the ignition.
Current:
00 V70 (Daily)
01 V70 (Trips)
94 300zx (High School Present)
01 V70 (Hub)
08 GranCher (Daught)
01 740iL
09 C40 (Son)
Former:
93 BMW 525i-Daugh's-Seized
02 Chrysler T & C-Kid Hauler-Fire
72 Buick GSX-Dad's-Corroded
76 Golf GTI-Mom's-Died
97 960-1st-Timing
00 V70 (Daily)
01 V70 (Trips)
01 V70 (Hub)
01 740iL
09 C40 (Son)
Former:
97 960-1st-Timing
I think you can still get in through the trunk on an 2002...on my 2005 you are really stuck if the key and fob stop working
neworleans
When insterted the key, it turns on either side but doesn't unlock the pin, also when you shake the door, i hear something loose.
How would you get in through the trunk? Is there a trick?
- 677 Views
- 773 Views
Last post by MadeInJapan
- 1258 Views
Last post by DavidE7
- 780 Views
Last post by nickbw898
- 42 Replies
- 8348 Views
Last post by imaV70Rdriver
