I have seen previously this topic but never get to the final answer to this problem.
I have brand new (Bosch)oxygen sensor - downstream, and the scan tools shows 0 volts. This is the second sensor i installed. Both sensors were brand new made by Bosh. From what I read about it, previously, few guys had same problems. They were installing new sensors, checking the wring and connectors and at the end the volt reading on the second O2 sensor was zero. Now, some guys say, that its supposed to be zero, some other guys say it should read around 0.47 volts. Beside that the OBDII says that the # 2 O2 sensor has fault, so I think there is a problem .
O2 sensor not working
- Year and Model: Many Volvos
- Been thanked: 76 times
Was this a Bosch Universal or a Bosch direct fit? The universals have been known to cause trouble at the splice junction so that would be the place to start.
It should not be zero volts.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Try with another scan tool.
Try with vol-fcr with live data version,for example.
Before that,give ecu a hard reset by disconnecting negative battery cable for about 15 minutes.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Where did you buy it? Lot of counterfeit Bosch stuff on market.
I think I would probe wiring for correct heater and voltage inputs once I knew the sensor wasn't fake
Strange.
The car was scan using different scanner - by Volvo, and it shows that the O2 sensor is working and both fuel banks .
My scanner and two other one (independent mechanics) are showing fault in one of the fuel banks and zero volts for rear O2 sensor.
I have Autel Al 619 OBD II reader.
- 684 Views
Last post by junlinshao
- 1283 Views
Last post by vtl
- 2011 Views
Last post by Ozark Lee
- 1997 Views
Last post by EngineeringBloke
- 762 Views
