Hello all,
Now that I have my car running (See post on Newbie Frustration) I replaced all of the deteriorated vacuum hoses on the engine. I replaced them one by one so that there would be no errors. I did not start the car for a few days and when I tried to start it, I had to crank it for about a minute or so before it fired up.
For the past few days, once I leave the car to get cold, I would have to crank and crank before it would start.
I am going to check my fuel pressure to see whether it is good. I have tried to prime the system, by cycling the ignition a few times to see whether it would start, but I am working blindly because I don't have a fuel pressure gauge to check. I will get one tomorrow.
I also saw that with the extended cranking when the car finally started the CEL stayed on. Yesterday, I disconnected the battery after the car warmed up and the check engine light stayed off all day.
This morning, after the extended cranking the CEL stayed on after the car started. Other than that the car runs and drives great.
Any ideas? I also need some specs to check my Coolant sensor. I will search around the forum for info in the meantime.
Thanks, Frank
1999 S70 GLT: Prolonged Cranking to start when cold
denraden03
- Year and Model: 1999 s70 glt
JRL
- Year and Model: Several
- Been thanked: 16 times
Usually an AWD fuel pump that causes this but I have heard of these do it too.
You may need to install an aftermarket fuel pump check valve
(Not hard and under $40, about an hour)
- Has thanked: 292 times
- Been thanked: 765 times
Jim, would you recommend a certain make/model of check valve when attempting this install, or will pretty much any one do?JRL wrote:Usually an AWD fuel pump that causes this but I have heard of these do it too.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
JRL
These:
https://www.amazon.com/S-U-R-and-R-Auto- ... B000T8YK0Y
You will also need to buy a fuel filter
- Been thanked: 467 times
Next time it happens, jump the fuel relay (jumper wire on terminals 15 and 87), maybe the fuel relay is "lazy" when COLD.
Loss of residual fuel pressure can be caused by:
- Bad check valve in fuel pump, if you have more than 200K, then it is not a bad idea to buy a new fuel pump, search for Bosch 69693 and the posts by "Stephansvolvo".
- Leaky fuel injectors
- Bad fuel pressure regulator.
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 111 times
Could be bad engine coolant temperature sensor as well. Do yourself a favor and check the connector for corrosion and give it a good cleaning.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
What is the code??????????
denraden03
@rspi: Don't know the code yet. I don't have a code reader. I will locate one today.
What are the specs for the CTS?. I will be checking fuel pressure sometime today.
Here are the specs from an old post by Lee:
0 degrees C - 5740 Ohms
10 degrees C - 3700 Ohms
20 degrees C - 2450 Ohms
40 degrees C - 1150 Ohms
80 degrees C - 318 Ohms
100 degrees C - 184 Ohms
Which pretty much matches the table from the 850 manual:
ENGINE COOLANT TEMPERATURE SENSOR RESISTANCE TABLE
Temperature F (C) Ohms
32 (0) .............................................. 7300
68 (20) ............................................. 2800
176 (80) ............................................. 300
212 (100) ............................................ 150
'06 S60 R, 197k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
denraden03
So, I purchased a Fuel Pressure Gauge and an OBD II Code reader.
Here are the results:
Fuel Pressure Gauge Connected: Key "ON" Pressure immediately @ 44 psi. Key "OFF" Left connected for about 2 hours, pressure maintained @ 44 psi
Conclusion? Fuel Pump and Relay Good.
OBD II: Code P0013- Camshaft Position Actuator Circuit/Open Bank 1
Cleared Code. Attempted to start car, Same prolonged cranking as expected. Car started. Check Engine light off.
Is the Camshaft Position Actuator for the VVT or the Camshaft Position Sensor.
Please explain this to me in layman's terms.
Is Bank 1 the exhaust camshaft? This the cam where I have the VVT and CPS attached. There is nothing on the intake cam.
Where do I go from here?
What do I check next, and how?
Thanks, Frank
Thanks, Frank
