ive got a 2002 V70XC and needs to have abs module, currently it has a failed abs module from XmodeX out in canada, they want over 500$ to send out current one to get repaired and sent back. I know some guys fix OEM ones but i have no idea what part number originally it had.
Thanks
XomodeX abs module
precopster
- Year and Model: Lots
- Been thanked: 128 times
In 2002 they have BCM which is programmed to your VIN. A 2002-2004 BCM from any P2 series should suit. You can get another from a wreck however you'll need a Vida Dice setup to read the network numbers from the old BCM and compare it to the replacement while it's plugged in (before screwing it in permanently)
