Howdy all,
Yesterday I was trying to disconnect the fuel line in preparation of removing the fuel rail on my 850T. What ended up happening was that the part that plugs into the fuel rail came out.
I put it back in but whenever I try to start it fuel shoots all over the place.
Is there a gasket or some other method required to create the necessary seal?
Thank you,
kimberly
Fuel Line plug into Fuel Rail leaking on 850T 1996
kimothyanne
- Year and Model: 850T 1996 Sedan
kimothyanne
Ah-ha! The "O" ring is still on it but there was no screw to be found. Also, the triangle part wasn't in the shape of a triangle any longer. Should I replace the "O" ring?
Thanks for your help.
kimothyanne
Okay. For the life of me, I cannot find where the triangle part gets screwed/attached to. Is it on the fuel rail itself or elsewhere?
Thanks again.
Thanks again.
- Been thanked: 504 times
You need to read the thread below, according to "jimmy57", if you are in a pinch, you can use Teflon tape, just make sure you apply Teflon on the threads only, don't allow the Teflon to inside the piping/fuel rail inner part:
https://www.matthewsvolvosite.com/forums ... hp?t=50033
- 337 Views
Last post by misha
- 434 Views
Last post by cn90
- 6807 Views
Last post by rspi
- 5505 Views
Last post by precopster
- 627 Views
Last post by Vovo_merz
