1996 volvo 960 p0500
Hi so my car just threw this code the other day. So I have the check engine light and transmission wse lights flash and so does the up arrow no speedometer and my abs light isn't on .when I reset it the speedometer usually works but intermittent flips around . I checked my antilock brakes when the lights are light up by stopping on ice and can tell the abs is working. So I am so confused about all I read i am pretty sure it's the sensor that send the signal to my Speedo but I'm not sure what one the differential or transmission .anyone please help
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
1. Check each wheels speed sensor and wires, and then tighten wheel nutsJp801utah wrote:So I am so confused
2. Speed sensor A -(error code P0500)
3. 2000 S70 Wheel sensor P0500
4. OBD II Fault Code OBD II P0500
Fault Code Definition Vehicle Speed Sensor Malfunction
- 93Regina
See if enclosed is related to your vehicleJp801utah wrote:Do you know what the values should be
94ABS960.pdf- (211.44 KiB) Downloaded 536 times
- 2464 Views
Last post by TripleThreat719
- 1013 Views
Last post by cn90
- 2915 Views
Last post by pokey1
- 773 Views
Last post by kiwi1950
- 947 Views
Last post by 93Regina
