Which 850 turbo ECU came without EGR and SAS?
IG-88A
- Year and Model: '94 854T-'95 855GLT
I have a '94 850 turbo, and recently acquired a NA intake and throttle body along with the proper 960 throttle plate. I'd like to give it a go without tapping the manifold for EGR. I've heard that there are some '96 cars that had neither SAS or EGR and would like to pick up the proper ECU so that I don't have to worry about my EGR anymore. I just want to make sure if I buy a '96 ECU, that I don't end up getting one meant for a SAS car, or one with EGR. Is there a particular part number to look for? I called Volvo and they said they didn't have any different configurations listed for a '96. Hoping someone here can point me in the right direction.
- Has thanked: 17 times
- Been thanked: 35 times
That's a tough one. My son's '94 850 (non-turbo) had an EGR...I thought only naturally aspirated cars came that way.
You can do an SAS delete easily- just soldering in a cheap resistor between 2 pins on your ECU as I did on my '98 S70 (and I yanked the secondary blower out from under the battery), but I'm sorry but don't know a thing about an EGR delete. Did a google search and found this regarding the EGR. http://volvoforums.com/forum/volvo-850- ... yes-31523/ You might search and find more.
tryingbe
- Year and Model: None
- Has thanked: 1 time
- Been thanked: 26 times
I use Volvo 850 T5-R 240HP 0261204134-355830 with no EGR and no SAS. It also works with an automatic transmission and does not give a CEL for manual swapped car.
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
- 1575 Views
Last post by wyoben
- 866 Views
Last post by wapitiscat
- 5251 Views
Last post by matthew1
- 11 Replies
- 3101 Views
Last post by tryingbe
- 9745 Views
Last post by RickHaleParker
