First Time clutch replacement... Removal of clutch and Transmission (225,000 miles). I am 25 percent into this job so far. Pulled axles, and supported (from above) engine, steering etc. Car is raised and supported safely. Ready to drop sub-frame and I will detach transmission from engine.
Here is where I can use some help. Does anyone have a diagram, picture or other clear instructional for which bolts I need to remove to separate the engine from the transmission. A good photo with the correct bolts circled for example would greatly help idiot proof the process so that only the correct bolts are removed. This link shows instructions I am following but the author did not get specific as to which bolts will separate the trans from engine. https://www.matthewsvolvosite.com/forums ... ch#p199389. Any help identifying the correct bolts to remove for detachment of transmission from the engine would be of great help. Thanks Then that info can be linked to the MVS tutorial shown and can help me and any other brave souls taking on the challenge.
98 V70 FWD Clutch/Transmission
cuhfs
- Year and Model: 850,XC70,XC90,S60,80
- Has thanked: 17 times
- Been thanked: 31 times
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
96 850 Wagon Manual Trans & 98 V70 (gone)
95 850 Sedan Auto Trans (gone)
04 XC70 Auto (gone)
04 C70 Convert (gone)
01 C70 Convert Manual Trans (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
tryingbe
- Year and Model: None
- Has thanked: 1 time
- Been thanked: 26 times
Any bolts that go thru the bell housing and engine will needs to be removed as well as the starter. They are all 14mm head, if I remember correctly.
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
- Year and Model: Many Volvos
- Been thanked: 76 times
There are a couple of them on the back that you can't really see, you need to find them by feel.
cuhfs
Okay thanks & Stay tuned... first timer here
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
- 570 Views
Last post by cuhfs
- 1049 Views
Last post by cuhfs
- 18 Replies
- 2675 Views
Last post by theWIFES_S70
- 28 Replies
- 9194 Views
- 2015 Views
Last post by Lelica
