I have a set of 'R' model floor mats (carpet type not rubber) with the "R' logo on them that I picked up. The front mats have holes in them for the pins at the rear of the carpet to hold them in place. Should there be a plastic grommet of some sort to prevent the mat coming loose? All my recent P80 experiences even in PnP have rubber Volvo mats, but if I recall the 850's had a plastic clip that held the carpet mats in place over the 2 pins.
Any advice/clarity or pictures of offending articles would be appreciated.
P80 floor mats - 'R' model
- Has thanked: 2199 times
- Been thanked: 1851 times
- Has thanked: 316 times
- Been thanked: 531 times
There are two pins in my floor for the mats, on both the driver's side and passenger side. They are pushing holes into my universal rubber mats, I should probably drill through them to make it a cleaner fit.
Mine are the same, but if I recall correctly, the over-mats (carpet type) that Volvo used had a plastic ring around the 2 holes to give them more strength against ripping, so if anyone can confirm this I'd appreciate it. If you have these carpet mats (not necessarily 'R' versions but any) a picture of how the pins fit would be great.
Thanks,
Thanks,
JRL
- Year and Model: Several
- Been thanked: 16 times
Plastic ring.
Pretty hard to snap in if you have weak fingers, it takes a pretty hard push
Thanks Jim. I thought my memory was not completely shot! I'll have to keep an eye out for some of those rings then.
Appreciate the help!
Ah, I see. Misinterpreted your question at first.scot850 wrote:Mine are the same, but if I recall correctly, the over-mats (carpet type) that Volvo used had a plastic ring around the 2 holes to give them more strength against ripping, so if anyone can confirm this I'd appreciate it. If you have these carpet mats (not necessarily 'R' versions but any) a picture of how the pins fit would be great.
Thanks,
I have looked up on Vida and found there is a kit and also 2 parts of a ring that can be bought. Thanks for the help anyway.
I like that there are all these kits around. There are quite a few that I need to track down.scot850 wrote:I have looked up on Vida and found there is a kit and also 2 parts of a ring that can be bought. Thanks for the help anyway.
