05' V70 forgot to tighten oil plug
850 LPT
Has thanked: 335 times
Been thanked: 247 times
Post by 850 LPT »
So my biggest fear came true last night.
I was doing an oil change with the typical distractions, dropping off a kid, walking the dog, dinner etc.
So at some point in the evening it dawned on me through divine intervention :o . I put the plug back in handtight, then changed the filter and I never went back to actually tighten the plug. Of course now it's late and the car is already on the ground again, so I wrote a big note to myself to do this first thing in the morning.
Stupid me of course wasn't smart enough to check if there is oil leaking out, but luckily there was only a small puddle this morning.
Sometimes I think I should just stop wrenching and leave it to the pro's.
Do you guys have any story's like this? Or am I the only knucklehead? Wait, don't tell me.
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
MarcM
Year and Model: 2005 S60 2.5T AWD
Has thanked: 1 time
Been thanked: 3 times
Post by MarcM »
You didn't drive it. That's a good thing. Not sure if these cars have low oil protection shut-off, so hard to tell if it would have saved the engine if the plug had worked its way out.
I suffer from CRS so I have processes. When the oil is done draining I install and tighten oil drain, then install new filter and tighten, and of course add the new oil.
2005 S60 2.5T AWD
IPD mods:
IPD HD PVC intercooler coupler/upper, HD Subframe poly inserts
ProPartsSweden HD top mount square mount, PPS lower torque rod & control arms.
Clockboy
Year and Model: 05 xc70, v70 2.5t 06
Has thanked: 2 times
Post by Clockboy »
If you go through the old posts you will find tons of equally forgetful things. I had changed the inner tie rod and when I had everything back together took it up to the school to see if all was ok. An annoying vibration began and just got worse. I drove slowly back to the house as I cataloged all the stupid things I could have done. Went to take the wheel off and realized I had just hand tightened the lug nuts - My neighbor came over between dropping the car and torquing the nuts and I completely forgot. That is just one of the many.
Has thanked: 1610 times
Been thanked: 4065 times
I once filled SWMBOs car with oil without even putting the plug back in and ended up with 6 quarts of synthetic on the driveway. Thankfully, most of the really knucklehead things I've done......I can't remember.
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
My biggest "forgot to do" problem is wheel lugs. Usually with my car, where I can detect it quickly and act, but once it happened with wife's car.
I do not interrupt when wife's calling for dinner/walking the son/changing the diaper, with exact this motivation: I'll forget to do something and it will cause safety problems.
That's normal with humans. That's why there's independent quality assurance people in all life/health threatening engineering processes.
packetfire
Year and Model: 2010 v50 2.4i
Has thanked: 17 times
Been thanked: 30 times
Post by packetfire »
At risk of seeming pedantic, a checklist is a handy thing, which is why pilots, astronauts, surgeons, and other people who have incentive to avoid ever having to say "oops" use them, and obsess over them.
But when inserting a fastener, unless one needs to leave it loose to wiggle the assembly into place, one should tighten it when first inserting it.
I use my phone to take photos of things like my unplugged coffee pot before I leave on a trip, so I can show my wife, that yes dear, the coffeepot IS unplugged. :)
1982 240DL: Drove it 32 years and 1.5 million miles (sold, even still had mint leather!)
2001 v70 2.4T: The most expensive $1500 car I ever bought ("Volvo Turbo" - what an oxymoron!) (sold)
2004 v70: Far less fatally-flawed v70 - It served well (sold)
2010 v50: Smaller, slightly sportier wagon. Its got a spoiler, so I upgraded with sway bars!
Lug nuts are a classic, so I use a routine with them.
Wheel back on, lugs tightened to square wheel, lower car, lug nuts torqued.
Then, and only then, move to next wheel.
You don't save any time doing 4 torques at end, it might even take longer
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 89 times
Post by chrism »
Oh my gosh, where do I begin?
Let's put it this way, one more big "ooops" and I'll be qualified to work at the Pep Boys auto center.
terryjr
Year and Model: 06 XC90 - 04 XC70
Post by terryjr »
I've had loose lugs twice. once by a shop, once by myself. I had car up on stands for a week or so. rotated tires while it was up. Then when i finished motor and I just lowered it down and drove off. It took 2 annoying vibe days later to remember my mistake.
nsjames
Year and Model: 04 XC70
Post by nsjames »
I once swapped a rear axle in a comanche.
I needed to wait for the RTV on the diff cover to dry, so I made a mental note (and now you see the problem) to fill the diff before I went to work in the morning.
Well I didn't.
and about 8 miles down the road the rear diff locked up.
So now i leave sticky notes on the steering wheel.
Thankfully it was just a D35, and I had a few more laying about. Still sucked to do the same job twice.
