'99 V70 Base -- Rear view mirror anchoring
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
Folks -- The internal rear view mirror is loose and I've got to tighten the mounting bolts. Can anybody give me a thumbnail as to how to get the reading light cluster out without damage so I can access the torn bolts anchoring the mirror stalk? I've redone the headliner in this car already so I've had the assembly out once before, I just can't remember how it comes out. Thanks.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
Teddy1975
Year and Model: 2007 V50
Has thanked: 1 time
Been thanked: 7 times
Post by Teddy1975 »
Remove the lense covers as you would to replace the bulbs. You should be able to see the two retaining torx 15 screws that holds the courtesy light assembly to the roof. Undo those and carefully pry the assembly off. There are retaining clips on three sides, the one facing the wind shield have no clips but two plastic mount points you really don't want to break. It should come off fairly easy.
Now you will have access to the base of the rearview mirror and the two torx screws there.
Current: V50 2.0D, 2007, 6 speed manual
Previous: 850 2.0L N/A, 4 door 1996 manual, 740 2.3L N/A, 5 door 1992 manual, and S70 2.5T 1999 manual
dosbricks
Been thanked: 4 times
Post by dosbricks »
Robert DIY video:
E Showell
Post by E Showell »
Thanks, guys
'95 855 auto (sold)
