2000 S70 Flashing Arrow
My 2000 S70, non-turbo (gas) has 132,000 miles and the Check Engine Light comes on intermittently and the flashing arrow comes on too. Sometimes the speedo is erratic or doesn't work but overall the car runs great. I read a number of articles here on the S70 forum and after looking at the codes I pulled P0717 and P0722. It sounded like it was my PNP switch. I have since replaced with a new one but still get the flashing arrow and CEL but now have a P0600 code (glow plug...my car is not a diesel) no longer have the other codes. Any suggestions would be helpful. Thanks
- shiloh51933
- Has thanked: 28 times
- Been thanked: 17 times
Flashing arrow, no good it means transmission issue.Samtara1 wrote:My 2000 S70, non-turbo (gas) has 132,000 miles and the Check Engine Light comes on intermittently and the flashing arrow comes on too. Sometimes the speedo is erratic or doesn't work but overall the car runs great. I read a number of articles here on the S70 forum and after looking at the codes I pulled P0717 and P0722. It sounded like it was my PNP switch. I have since replaced with a new one but still get the flashing arrow and CEL but now have a P0600 code (glow plug...my car is not a diesel) no longer have the other codes. Any suggestions would be helpful. Thanks
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Probably a transmission code. You need to find a Volvo specific type of reader to get the proper diagnostic.
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
You can go to a Volvo dealer or independent Volvo shop to have those codes read. They may charge you for it. Once you have the actual code numbers post back here and someone will be able to start helping you.
Follow-up...like a goof ball I didn't reset the codes after installing the new PNP switch. I reset codes and no more flashing up arrow or CEL! Drove it for 25 miles street and highway no issues so far!
The PNP switch was a new part for $68 at FCP Euro. The PNP switch replacement was easy and there are a couple of YouTube videos (Robert Spinner video was the best) that show you step by step on how to do the job. The toughest part is getting the three separate pin guides out. You will need MAF cleaner to loosen and lube, a small crevice tool (to hold down release tab) and then slightly tug on wires lifting up after removing all boots and zip ties. Simple job without any specialty tools.
- rspi
Contact rspi..
Good deal. Hope all stays well.
- Has thanked: 316 times
- Been thanked: 531 times
Glad you resolved your issue. The key with the PNP switch connectors is patience. Gently pull it out without breaking it.
- 2469 Views
Last post by polskamafia mjl
- 470 Views
- 1272 Views
Last post by jose456891
- 30 Replies
- 7379 Views
Last post by goldmandan
- 1358 Views
Last post by RickHaleParker
