Random Misfire Cylinder #4
JeffHicks
Year and Model: 1989 240 Wagon,
Post by JeffHicks »
I continue to track down weird little issues with the crippled '04 V70 I bought...
On cold & cool starts, it will stumble a bit and has a miss. After running for several seconds it will begin to hit on all 5 cylinders & run great.
Finally I got another misfire code. Cylinder #4 - one of the cylinders I've had a previous random misfire on. This is the cracked wire cover I found.
Now... Would a nice coat of Liquid Tape do the trick for this wire? Or would you recommend replacing it entirely? Your thoughts?
1989 240 Wagon, 1999 V70 Base, 2002 XC70, 2005 V70 T5
Has thanked: 1609 times
Been thanked: 4065 times
Jeff - you might need to cut that and splice it back together firmly to make it work, not just tape it. Solder would work too.
JeffHicks
Post by JeffHicks »
^ Thank you!
I will likely end up doing that in the long run (specifically, when it's no longer winter!). But for the time being I decided to coat it good with "liquid tape." For the next month or so I have no driving to do, outside of puttering around town. That should be a good gauge of whether or not I've solved the riddle.
I think the 2004 and 2005 wiring are the same on the coils...
Note the different color wires are the control signals - grounded at the ECU to fire the coil.
The Green white supply 12 VDC to the coils.
Terminal 2 provides fire diagnostics to ECU ?
and the SB wires from Terminal 3 are grounds.
Screen Shot 2016-02-22 at 1.38.50 PM.png (106.34 KiB) Viewed 1421 times
terryjr
Year and Model: 06 XC90 - 04 XC70
Post by terryjr »
haha, dont say #4 misfire around a Subaru guy, sure way to give him anxiety. Almost always means a cracked piston ringland
JeffHicks
Post by JeffHicks »
terryjr wrote:haha, dont say #4 misfire around a Subaru guy, sure way to give him anxiety. Almost always means a cracked piston ringland
Head gasket.
HEAD GASKET!!!!! :D
terryjr
Post by terryjr »
ya thoise too. I have about 16 head gaskets hangin up in the garage. Only one or two actually blew the rest were ringlands and bearing failures
