Head gasket or new motor?
Hi all . 07 xc70 with the missing coolant issue. Replaced water pump,hoses,thermostat, coolant cap. I can't find the coolant leek. Top radiator hose gets hard until I release pressure. Car does not over heat,but add coolant light goes on. Does not misfire or have coolant in oil. What gives,anyone else been thru this ? Thanks
quite possible.DeanY wrote:Even with no compression leak or misfire?
have the coolant checked for exhaust gas.
https://www.amazon.com/UVIEW-560000-Comb ... B000NPDL76
- JudgeRat
- Year and Model: s60 2004
- Has thanked: 3 times
^^what he said. Check for exhaust gas in coolant. I had a similar issue when my head gasket went out with an internal leak to cylinder #1 on mine in the past. Not a fun situation.
"Molly" - Black 2004 2.4L i5 (non-turbo) T5 Auto FWD P2 Volvo s60 w/all options
Old-school race guy: "Brakes 1st, then steering, tires, wheels, & suspension, only then engine and drive-train. No sense making it go if you can't stop & steer properly...Safety first people!"
- 26 Replies
- 5892 Views
Last post by SuperHerman
- 18 Replies
- 5820 Views
- 472 Views
Last post by erikv11
- 11 Replies
- 2569 Views
- 20 Replies
- 3332 Views
Last post by NYCKID221
