should the A/C compressor be on all the time when set to min?
Clemens
Has thanked: 498 times
Been thanked: 228 times
Post by Clemens »
Hi!
THe other day I thought I´d use the A/C a bit so it won´t seize. Themperature was in the range of 55-60 degrees. The compressor came on and off while driving which is normal, I´d say if the exterior temp is lower than the interior temp. But then I set both climate control knobs to min, opened the hood and expected the compressor to run all of the time. But it came on for a few seconds, then off for a few, then back on.
Keeps me wondering: Is taht normal even if the AC is set to min? Or is this an issue with the clutch gap or am I in Need of an AC Service/refill?
It worked alright last year.
Btw, it´s a 96 855 R.
1996 855 R,
2010 V70 D5,
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
Measure the gap.
Measure the pressure in the system.
Those are the only two accurate way to tell.
85 GLH, 367 whp
00 Insight, 72 mpg
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
That's how it works, it's cycling, the compressor doesn't work continuously.
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
A little beside the point but the compressor will also come on to defrost the windshield. So if you've been using the defrost function during the winter you don't need to worry about the compressor seizing.
Clemens
Post by Clemens »
Thanks for the input. Today I did some testing and it seems like the System pressure is too low. So I guess I´ll Need a refill at least. Hopefully not the evap.
Speaking of the devil (evap): anyone ever tried to fix a bad evap with some sorta AC sealant? Given the hassle of taking all that apart (and putting it back together correctly) it might be worth a try.
1996 855 R,
2010 V70 D5,
Has thanked: 1610 times
Been thanked: 4065 times
Using sealant is 1000 USD roulette. The orfice tube on these systems is small and it is easy to plug.
The only fix for leaking AC is replacing bad parts ..in this case almost certainly the evap.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
polskamafia mjl wrote:A little beside the point but the compressor will also come on to defrost the windshield. So if you've been using the defrost function during the winter you don't need to worry about the compressor seizing.
No it will not if outside temperature is below 2 degrees Celsius.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
misha
Post by misha »
oragex wrote:That's how it works, it's cycling, the compressor doesn't work continuously.
In the summer temperatures,when system is properly charged and pressures ok,compressor will run all the time without cycling.
It starts cycling when refrigerant level drops,or when outside temperatures are colder.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
polskamafia mjl
You may be right, Misha, although I've never heard that before but it does surprise me. Where did you read that?
misha
Post by misha »
No need to read...try it and you will see. ;)
That's a protection for ac compressor from seizing.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
