Recurring 313 code with new PNP switch
ducttapeandzipties
Year and Model: 1989 245DL
Post by ducttapeandzipties »
I have a 94 850 GLT.
It began having the flashing arrow and stuck in third problem. I replaced the PNP, cleared the codes and no luck, same symptoms and the code comes right back. I took out the battery again and tried adjusting the switch, no matter which way I turn it, if the transmission is in reverse, the reverse lights are on.
Am I missing something? Should the transmission operate normally after replacing the switch and clearing the code? Or do I need to look deeper for some other problem?
goldmandan
Year and Model: 1999 S 70, 2000 V70
Post by goldmandan »
I had this SAME problem with a 99 S70. Went to the junkyard and got a transmission control module with the SAME part #. 10 minutes later the car ran like new again!
Good luck
Dan
ducttapeandzipties
Went down and got a junkyard TCU and no luck. Same problem. What else could possibly be wrong? Wiring?
ducttapeandzipties
The girl took the car to a shop, they said it was a bad pnp switch. FCP accepted the return and issued refund.
beigg
Year and Model: 850 97
Post by beigg »
Was the fcp pnp a refurb?
ugh smh 850 Turbo fridge
beigg
Post by beigg »
Wondering if taking the fcp one apart would resemble a failed one?
Has anyone posted pictures of the 850 pnp disassembled and the rebuilding process?
