1996 Volvo 850 Brake Pad Half Shims
wackenhut
Year and Model: 850R 1996
Post by wackenhut »
Hi,
So I am experiencing the dreaded vibration with the rear brakes and purchased the half shim kit from volvo. When I look online at the volvo factory pads, they are attached to a backing with two holes, is this considered a shim? I am just wondering if the half shim metal kit goes on top of this piece or if it needs to some how be taken off and reattached to the metal half shim.
If someone could please explain that would be great!
Thank you.
Reason: Clarified title - please, no CAPS in titles
dosbricks
Been thanked: 4 times
Post by dosbricks »
The pad backing (steel) is coated with something that is supposed to reduce vibration, but in my experience, only the L-shaped shims are effective. The pad backing is not removable.
Remember the arrows on the shims must all point in the direction of forward wheel rotation (or up in the case of the rear brakes). Use silicone brake grease on all.
wackenhut
Post by wackenhut »
Thank you so much!!
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Almost all reputable brake pad manufacturers now have something like brake shim in the back of their pads.It's glued at the back of the pad and almost looks like it's a single piece.
Those are Mintex,Trw,Delphi,Ferodo.
I installed Delphi (Ac Delco for U.S market)rear brake pads few months ago and they had factory shims at the back.
They sometimes squeal ONLY when i brake while driving in reverse while i park the car.Before them i had ATE from Volvo and they behaved the same.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
dyn blin
Year and Model: 1997 850 Wgn
Has thanked: 1 time
Been thanked: 2 times
Post by dyn blin »
When I pulled the pads from the rear during Stage 0 update after purchase, one side had the arrows pointing counter to forward wheel rotation. Wear appeared "normal" and even, no squeal (one of the few things that didn't make noise when I bought the moose). Looked about 50% worn-
What's the effect of reversed pads with shims?
'97 850 GLT Wagon- Driving to see 300k in the rearview
misha
Post by misha »
Not reversed pads with shims....shims are fitted at the back of the pads to prevent squealing.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
dosbricks
Post by dosbricks »
Misha, I think he means the shims were upside down on either one side of the car or on the opposite side of the rotor--not sure which.
dyn blin, it appears the L shaped shims were designed to put unequal pressure on the pad in such a way as to eliminate squeal. As pads and rotors wear down toward the end of their usable life, squeal tends to become more of a problem.
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
I throw away the shims b/c to me they are almost worthless.
I use anti-squeal compound and Mintex FWIW.
dosbricks
Post by dosbricks »
cn90 wrote:I throw away the shims b/c to me they are almost worthless.
Where did you find the Mintex rear pads? The last time I did a brake job, I could not find the rears anywhere online--only the fronts.
Post by cn90 »
dosbricks,
http://www.autohausaz.com/ sells REAR brake pad by Mintex for $18 or so.
Free shipping if the order is > $75 or so.
