After I drive around for awhile maybe stop at a store then drive around then stop again stop at another store for 20 minutes or so then turn the engine on it idles rough until I drive away even a short distance the it idles normally, is it a bad idle control valve/ slide valve?
My mechanic did a fuel pressure check and and injector leak check the leak check was good but he said the spray was poor and also cleaned the idle control valve and replace a hose connected to it
The vacuum hoses are good
New mass flow sensor installed last year
Could it be the fuel pressure regulator, the problem is intermittent and there are no codes. The next time that it happens I will do nothing and see if it corrects itself or stalls out
Thank you
Idling problem 1998 C70 2.3L HPT 317000 miles
Racerxc70
- Year and Model: C70 1998 coupe
I replaced the Throttle position sensor and the Turbo intercooler intake hose, the sensor had a lot of miles on it and the hose was just plain soft and badly worn I haven't had any reoccurring problems since
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
Thanks for the update!
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
What is your mileage now?
Current Volvos:
Racerxc70
The TPS may have been just fine but for $38 USD I'm not upset, the worn and soft Turbo intercooler intake hose was most likely collapsing during hot idle starts and also high acceleration ( also under slow speed acceleration there was a weird humming noise) Since I replace the Turbo intercooler intake hose the hot idle problem is gone the weird humming noise is gone and the performance is back.
I also replaced the Turbo boost hose, it was brittle on one end, its in the same area located underneath the air box, why wait for a problem.
- sleddriver
- Year and Model: 1998 V70 T5
- Has thanked: 11 times
- Been thanked: 13 times
To Racerxc70. Thanks for posting this. Have experienced similar, inconsistent issue. MY TPS is now 19yrs old; factory original. I wonder if cleaning it is a possibility? I'll have to look.
M1 10W-30 HM
M1 10W-30 HM
Racerxc70
As my post stated my TPS is 19 yrs old but I really think that the Turbo intercooler intake hose was really the problem, if yours is like mine was soft and deteriorating that most likely is the problem, this hose connects directly to the Throttle body and it is my belief that time and heat causes it while under pressure from the massive air intake to partially collapse.
The OEM part is about $150 USD the aftermarket hose is about $50 plus new hose clamps, I was able to compare both and they are exactly the same.
I bought my TPS from VOLUPARTS.com $38 plus shipping
- 644 Views
Last post by foggydogg
- 13 Replies
- 3346 Views
Last post by clifford06
- 1448 Views
- 1511 Views
Last post by Lasershark
- 1692 Views
