$15 Keyless Entry Solution
cyberwolf
Year and Model: S90 1998 , V70 2002
Post by cyberwolf »
I recently scored a '98 S90 which of course came without any remote keyfobs. Being the cheapskate that I am, I started looking for alternatives to $50+ keyfobs. I came across a Bulldog keyless entry system on Amazon for $14.95 and figured I'd give it a try. After just a little work finding the wires, it works like a charm. I now have two remotes for 1/4 of the price of one original Volvo remote.
For anyone looking to do the same, all wires can be accessed in the left drivers side kick panel. There's a connector up in there that feeds the door. The following connections were found on the Bulldog site and worked perfectly.
Keyless Module --- Wire Harness
Red --- Positive (I used the Green/Red on the harness)
Black --- Ground
Purple --- Ground
Purple/Black --- Ground
Blue/Black --- Green/Black (unlock)
Green/Black --- Brown/Black (lock)
The remotes also have a programming feature that allows you to set a .7 second double click, which is what you need to unlock. Otherwise you need to press unlock twice slowly.
Now on to the A/C troubleshooting...
2002 V70
1998 S90
2006 Chevy HHR
2002 Dodge 1500 Van
1998 S70 Totaled
