Drivers Side Headlight Failure
MammothLakes!
Year and Model: 2004 V70
Post by MammothLakes! »
2004 V70. I have replaced the ballast, igniter, cable connecting them, as well as the shunt which was not black or deffective so far as I can tell. Just turned it on and light comes on for 10 seconds or so, turns off for 10 seconds or so and comes back on. I'm losing my mind. Please help!!!
packetfire
Year and Model: 2010 v50 2.4i
Has thanked: 17 times
Been thanked: 30 times
Post by packetfire »
I saw these same symptoms when installing aftermarket Xenons from "retrofit source". As you know that the passenger side does NOT exhibit the problem, swap components between the two sides until it is the passenger side that shows the failure. The last component swapped is thereby the proven defective one, and can be moved back and forth, and the problem will follow it.
1982 240DL: Drove it 32 years and 1.5 million miles (sold, even still had mint leather!)
2001 v70 2.4T: The most expensive $1500 car I ever bought ("Volvo Turbo" - what an oxymoron!) (sold)
2004 v70: Far less fatally-flawed v70 - It served well (sold)
2010 v50: Smaller, slightly sportier wagon. Its got a spoiler, so I upgraded with sway bars!
shiloh51933
Year and Model: 04 XC70/'98 V70XC
Has thanked: 28 times
Been thanked: 17 times
Post by shiloh51933 »
MammothLakes! wrote:2004 V70. I have replaced the ballast, igniter, cable connecting them, as well as the shunt which was not black or deffective so far as I can tell. Just turned it on and light comes on for 10 seconds or so, turns off for 10 seconds or so and comes back on. I'm losing my mind. Please help!!!
Not sure if you ever figured this out but it's sounds like a failing xenon bulb. I'm sure you replaced the xenon bulb first but those symptoms sound like an old bulb on it's way out.
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
